Old 08-07-2007, 10:49 AM   #3
FrayAdjacent
You can adjust your AC settings by hitting the + and - buttons under the temperature display.
If you hit the - until it says 'Lo', and it's still not blowing cold, the Durametric tool will not help you. You will need to have your AC system serviced. Likely the level of coolant is too low.
2. It should be able to read the mileage from the DME. The only way this would be different than what you see on your instrument cluster would be if the instrument cluster were replaced, and not cleared before being installed.
3. I think the only 'option' you could turn on would be the outside temperature display, if your car doesn't already have the OBC (onboard computer)
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
