Originally Posted by 2000SoCalBoxsterS
Easy for you to say & do. What kind of tools or power equipment is needed to take a 3/4 piece of aluminum and flatten the ends and drill the holes, and finish it off so nicely. Do you have the tools at home or did you do this at work?
SORRY never came back to check this thread, never too late
To fabricate the bar is a joke, i used a 3/4 diameter aluminum bar, used a file to make 2 flats at each end to facilitate drilling 7/16 holes and so that the 3/8 X 2 inch screws and lock washers sit on a flat surface, then i removed the existing metric screws on the triangular plate and installed the bar over it.
With all materials on hand this is a 45 minute job max.
If you have any other questions I'd be glad to help.
Franco
