Thread: 911 vs boxster
Old 08-04-2007, 05:35 AM   #1
Adam
Originally Posted by spine911
Personally, i wont trade your 987 with a 996. ALL 996s/986s are prone to RMS leaks and possibly Intermediate shaft failures due to a casting flaw from the factory. I myself wont trade piece of mind for HP. But i would definitely trade a 986 / 987 /996 for a mint 993. Just my 2 cents.
I think you are referring to the porous cases that affected some early boxsters. The RMS IMS failures aren't a result of a casting flaw. The RMS usually occurs because the crankshaft is not supported sufficiently and it distorts the seal causing oil to blow by. I believe IMS failure can happen a couple different ways, but these are due to design flaws in the m96 engine not casting flaws. These flaws were not completely fixed on the 987 series cars either.
Originally Posted by joyfrog
also as I`m sure you know porsche`s in general have problems with the clutch`s as well, boxters are about half of the cost as a 911 to replace, just in case you were going to go with a standard transmission.
Really? I think both cars demand about the same amount for labor and parts for a clutch job. What are you basing this statement off of?
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
