Old 08-03-2007, 07:24 PM   #2
chitowndad
Found the source of the leak
I figured this one out. There is a tube that runs along side and under the Air Oil Separator hose and it's shaped like a stretched "S". It also looks like an accordion on one of the ends. There's a clamp that appears to be not that tight. The clamp looks goofy and I'm not sure how to tighten it. It looks like I need a special tool (like a crimp tool) to remove or tighten it.
See the attached picture. The screw driver points to the clamp...
I'm still thinking of replacing the Air Oil Separator as well. I found it on an auto discount part store online for $100. Is this part difficult to replace?
How do you disconnect the hoses on the Air Oil Separator?
Thanks,
-Steve
chitowndad is offline   Reply With Quote
