Originally Posted by iflyadesk
PSS9s require some sort of spring modification (I'm sure you guys know what parts I'd need to accomplish this) and ideally need revalving to accommodate springs that are twice as stiff as what it comes with.
Have you talked to the BSR guys who run the stiffer springs on the PSS9s? I don't believe they have revalved... Is it that big of an importance? I understand you are trying to get the best car you can, but isn't that a little overkill? I know ruf and matheney racing in germany use revavled PSS9's...
As far as the cross coilovers... there are only a couple of boxsters I know of who run them, but both are on the street. Bruinbro on most of these forums does a ton of track stuff, and he has them.
