I can tell where that picture of the engine is, That oil is right under the AOS oil lines and under the Engine Oil filler Flex Tube.
Looks like i see some oil stuck on the Engine Oil filler tube... Could either be that OR the AOS is leaking oil on top of the Engine Oil filler tube, then it drips down to the engine crevas which means your AOS (Air Oil Separator) is bad. Tell me, Has the car ever smoked for about 20 seconds once or twice during start up since your ownership... if so... AOS is ready to be replaced.
