Old 08-02-2007, 03:23 AM   #3
ccwchew
hahaha... yeah it's true, you can't pick up coins with magnets
by the way, two other questions about short shifter:
1) once you cut out the original plastic shifter, can you ever re-use it again?
2) i noticed the metal shaft to the gear knob on the original shifter has a bend (roughly 20 degrees) towards the right hand side of the car (i'm assuming because mine is a right-hand drive). Pictures of the short shifter looks like they have a straight shaft. Do you guys think it would make it little harder to use?
2003 Speed Yellow Boxster S
ccwchew is offline   Reply With Quote
