You should not need an alignment with wheel replacement. and the camber should be that neg in the back.
when I did set ups on porsches the back had almost 1-1.4 deg neg camber and the front had .5-.75 deg neg camber..
the fact that they are wider than the originals might make the camber look worse, but it wont change it...
