Old 08-01-2007, 06:53 AM   #6
blue2000s
Porscheectomy
Originally Posted by easyc
It isn't really necessary, but if it has been a awhile since your last alignment it won't hurt. If you feel vibrations while driving as well you might want to get one also. Is you car lowered? The Toe is what you should be worried about, not the neg camber... that will only help your handling.
I agree with easyc for the most part.
Just changing wheels doesn't change your alignment settings at all. But like easyc says, if it's been a while, you might be due. It'll help keep the new tires from wearing prematurely/unevenly.
If you do alot of autocross and/or spirited twisty driving, some negative camber is a good thing, it helps with stability and actually does promote even tire wear, also as easyc says. However, if your driving is mostly straight line, highway type stuff, you'll get earlier wear on the inside of the tires because the loads will be concentrated there, especially with a stiff sidewall 18" tire.
