Old 07-25-2007, 11:48 AM   #1
jbboxsters
Suspension (lowered) issue
On my 02 Boxster S with lowered suspension the rear tires (and maybe the front but to a far less degree) have the camber off enough that it is visible from the rear of the car that the inside of the tires are going to wear much more than the outside. The tire store told me there is no camber adjustment and the only correction was to raise the car back up. Does that sound correct? The reason the car was at the tire store was because the rear tires were completely worn down on the inside edge only. I just purchased the car and was told it was lowered by a very reputable customizer.
Thanks,
Jerry
jbboxsters is offline   Reply With Quote
