Old 07-25-2007, 04:19 AM   #2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by mjstallion
my car is missing these underside covers... is that a problem? should i buy them?
First off, be aware that there aren't underbody panels that cover the entire underside of the car, just a few strategically placed black plastic panels in certain locations in the front section, midsection (drivers side to cover fuel lines/coolant lines). The rear section for the most part is left uncovered.
I'd double check at the dealer parts dept. which parts you really are missing. If you are missing some underbody panels, do get them replaced, as they serve two purposes: to smooth out the air flow below the car, and to protect vital fluid lines from road debris.
