Originally Posted by Topless
Sounds like just a broken wire to the temp sensor or a bad sensor. Once you find and fix the problem you still have to clear the error code to clear the CEL. I am more worried about coolant on the ground than a bad sensor. Are you sure it is coolant and not just AC condensate? Where is it coming from exactly?
Bingo! Good to know it was something simple. Boxters don't go off road very well. I lost an under panel once in a little off track excursion. Dragged it around for a while until I was black flagged.
