Thread: Spare removal?
Old 07-22-2007, 07:29 AM   #10
trube78
Spare Removal
I bought a Contintental Comfort Kit, about the size of a shaving kit, to replace the spare and use it when I need the space -- on a longer trip. Makes the front trunk big enough to handle a decent suitcase almost doubles the size.
I looked hard for the Porsche Notice about the spare tire removal and safety, vice the postings on numerous boards. The notice I found says that the car was tested with the tire installed and therefore the car's tested safety is only confirmed with the spare installed --- which is slightly different than that the spare tire was designed and installed as a part of the support . My bigger issue ... what do you do with the removed tire when you mount the spare? In the instances where you are on a trip, I expect the trunks are full (tire won't fit anyway since it is larger, most say put it in the rear and tie down the lid. Although a 17 will fit in the empty front.) The other option is to put it in the passenger seat if ... you do not have a passenger (and don't mind the risk of scratching up the interior/leather.) Of note this is an issue with many cars that use a space saver spare.
I have an 02 and an 06 if the firewall was "beefed up" significantly they did it stealthily. So ... I keep the spare in around town but remove it when I need the space on a trip. The Continental Comfort Kit is a great answer IMO. There are a few lower price alternatives or a 987 kit can be purchased from Porsche.
Hope this helps.
ATB,
Tom
trube78 is offline   Reply With Quote
