Old 07-19-2007, 06:56 AM   #11
Topless
Track rat
Topless's Avatar
Sounds like just a broken wire to the temp sensor or a bad sensor. Once you find and fix the problem you still have to clear the error code to clear the CEL. I am more worried about coolant on the ground than a bad sensor. Are you sure it is coolant and not just AC condensate? Where is it coming from exactly?
