Originally Posted by Sammy
BTW - I run 17x8.5's (OEM's without any spacers) all the way around with Victoracers (225 front/255 rear) and haven't had any problems, but I only do autocrosses. It currently handles very neutral but I'm considering going to 245's up front next time I need tires. At the same time, you're not going to fry your PS pump doing autocrosses...
This is true. Surely you won't damage your PS pump during a 1 minute Auto-X run.
Those problems all occurred on cars during extended 20-30 minute track sessions with oversize front tires. If you do track your car and run big rubber up front check out what others are doing: Beefing up front end steering components and a PS pump cooling system. Then you can run your car all day without worries.
