Old 07-11-2007, 01:11 PM   #2
FrayAdjacent
Take it in, unless you happen to have a pressure gauge.
If you have an AC pressure gauge, you can check to see if you're getting pressure at the low pressure side of the circuit. I think the lines are on the passenger side under the cover over the AC intake filter. Should be easy to check.
If you do have to take it in, have them pressurize the system and check for leaks. If no leaks, then it probably just has to be filled.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
