Originally Posted by noone986s
Hi,
I have been searching the forums and am interested in the idea of buying 4 wheels of the same size to use as track wheels.
One suggestion was to buy 8.5x17 wheels with 245/40x17 tyres. But what Offset would suit both front and rear.
The stock 17x8.5 rear has 50mm offset, but if I got four of these would that do the job? Or alternatively should I get 4 made up at offset XXmm?
Any advice would be appreciated
This setup may create problems for you such as significant oversteer and you may overheat and roast your PS pump. Several others have done this with supersize rubber up front. The Boxter spec racing series is using 225/17 and 255/17 on all cars which is a good compromise between weight and traction. That is the size I am currently using. Very neutral fore/aft balance.
