Old 07-03-2007, 08:06 AM   #2
John V
How much camber is excessive? My '00 S will align to zero rear toe with -1.4 degrees of negative camber. If you want less negative camber than that, you have to add toe-in.
The USA sport chassis (030) is no lower than the standard suspension so it aligns exactly the same.
There is a bit of slop in the bolt holes. In addition to turning the cams to align the car how you want, you need to toe the wheels out as much as possible manually (by pulling) with the toe adjusters loose. Then tighten the toe adjusters and use the camber adjustment cams to dial the toe back to zero. This will give you minimum negative camber and zero toe.
John V is offline   Reply With Quote
