Old 06-27-2007, 07:57 AM   #11
Perfectlap
Perfectlap's Avatar
If you can't wash your own car with a hose use Optimum No Rinse available at detailcity.com
Fill A bucket with warm water and drop in two ounces of No Rinse, mix it up. Dunk a sea songe or chenille sponge and wring out the sponge over the car for some pre-soak.
Dunk the sponge again and wipe down one panel at a time. While the car is still wet Spray the panel with a quick detailer (Try Chemical Guys or FK1, both sell by the gallon and cheap) and buff dry with a waffle weave towel (Pack Shack or Poorboysworld.com). Use the left over water to clean your wheels with a Meguiar's Gold Class wheel face brush.
If you can't get a bucket to wash use a 2 gallon pesticide sprayer from Lowe's or Home Depot. Same procedure, fill with warm water, drop in two ounces, close the lid on the sprayer, shake up and pump the sprayer. No Rinse leaves a very nice slick surface. If the surface isn't slick after cleaning the a panel you are using too much water or not enough No Rinse. I can do the whole car in under 15 minutes.
as for the bugs, If you use a good acrylic wax like Fk1 1000P, FK1 Pink Wax, Werkstatt Acrylic Jett Trigger, Rejex, Mezerna FMJ it should make the bug removal much easier.
1Z makes a great bug remover sold at openroadmotoring.com
BORN: March 2000 - FINLAND
