Originally Posted by porsche986spyder
Could be the Clutch Master Cylinder or Clutch cable is loose or slipping.
Hi,
There is no Clutch Cable in the Boxster - it's a Hydraulic Clutch. If it were the Clutch Master Cylinder, it's more likely that the Clutch would be inoperable.
I suspect the issue here is either old, hydrated, Brake Fluid (the Brake MC and Clutch MC share the same fluid reservoir), or that there is air in the system. In either case, a good Flush and Bleed is in order. Hope this helps...
Happy Motoring!... Jim'99
