we are talking about 2 different things here. The wires in the schematic picture I posted above are from the phone power cable plug. This is found behind/under the center console. If you pull off the carpeted side panels, dig around in there and you will find it. It is not connected at all directly to the head unit but can be used as a source to get both switched and unswitched power. Good luck.
