Originally Posted by Thumper
Your top light works?!?!?!?!?!
Jeff
Your top light doesn't work because the cluster came from a coupe, and is coded as such. If you recode it for a cab. it will work. This can be done with a PST2.
I know using the code for a 911 cab works as that is how i did my car when i updated it to the CAN bus system to run the 3.6. It may work if you code it as a boxster as well, but I haven't done it that way.
Todd
