Old 06-09-2007, 06:58 PM   #3
ethand
As wvicary stated, if yo are inclined, the connector for the fuel pump power and the measurement is under the battery. Remove the battery and tray, and yo are looking at the top of the fuel tank. Remove the connector, I think there are four wires, and measure the resistance between the white wire and the brown/orange wire ( these should be the smaller gauge of the four wires.
Put it all back together, do the smae again once you know the fuel level has changed by at least a 1/4 tank and measure the resistance again. If the resistance changes, it is probbaly not the sender.
E
ethand is offline   Reply With Quote
