Originally Posted by thomschoon
i was also wondering what kind of price it ended up costing you as mine started chattering today and I only have 33,000 so maybe a bit of oil is seeping. I was thinking of going to the Fidanaza flywheel as it would be easier to buy everything and get the fly wheel,pressure plate balanced in advance. Also wondering how lmany hours it takes to do this as I may just drop the rear suspension at the same time and install the 030ROW that has been sitting in the garage for a year.
Clutch replacement is usually between 8-9hrs. Not a one day job. By the way, after doing some extensive research on clutches before I bought mine, I found out that the High Performance clutches are not made to last as long as the O.E.M. clutches. I gues they are made stricktly for short term track performance and not long term street use. Something to keep in mind.
