Originally Posted by bmussatti
Tappy valve/lifter noise is common on cold starts. How long have you owned the car? Are you using the correct oil? Mobil 1 0W40. Running a higher viscosity oil (like a 15W50) will enhance the noise.
When you say "enhance the noise" do you mean it'll be louder or quieter?
I have the same issue as the thread starter, engine makes about 3-5 taps from the engine like a dry lifter or valve and then is quiet... if i imediatly turn the engine off and then restart it the noise will not come back again until the engine has been sitting for more than 2 or 3 hours.
