Hold on - let's clarify "put the key in and nothing".
Without the key in the ignition can you open your front hood or turn on your lights? If you can't get into your front hood - then it's your battery. But, if you can...
When you put the key in does everything else come on but it won't start? If so, are you fully depressing the clutch (hear the click)?
If you can get into the hood, other items come on, and you're fully depressing the clutch - then it's probably your ignition switch...
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
