Old 06-02-2007, 11:27 PM   #28
Thumper
Thumper's Avatar
Originally Posted by bmwm750
Interesting, my top light works just fine. When I first fired the car up after the cluster was in, it definitely seemed to be "thinking" for a while, and then all the lights lit up, went out, and lit up again. Upon removing the key and re-inserting, all my idiot lights work just fine.
Also, very interesting to hear that your fuel gauge seems accurate. Have you run it down near E yet?
Patrick
Your top light works?!?!?!?!?!
Ok, now I'm jealous. When I installed mine, it never went through a "thinking" stage. It just worked like it does now ever since I hooked the battery back up. I wonder if both the donor and recipient vehicles being the same model year has anything to do with it? Do you get a top open OBC display when you operate your top, or do you just get the idiot light? I'm wondering if there is an OBC display when the top is operated? Can you shoot a pic?
I haven't run mine down near E yet. I'm only down to 1/2 tank, but the reading vs mileage driven are exactly what my old cluster would've read. I know how many miles I was averaging per tank before swap, so I'm keeping a close eye on it for now until I can verify everything.
Jeff
Thumper is offline   Reply With Quote
