Kevin,
I have an O2 problem also. I'm waiting for the replacements to arrive. The job of replacing them couldn't be easier. You just unplug the wiring, and remove the sensors from the exhaust with a 22mm open end. Reverse the procedure and you're done.
Properly jacking the car up will take almost as long as the actual job
