Old 05-31-2007, 07:24 AM   #31
porsche986spyder
Originally Posted by Thumper
Mine is a 2001. The gauge needles can be a real bear to get off. I take a pic of the gauges before disassembly and then refer to it when I put the needles back on. I haven't had any trouble getting them to line back up just like they were when I removed them, but I could have just been lucky.
Try to find a cluster than you can verify is good. The first cluster I got looked perfect, but something was fried in it, as when I hooked it up I did not get any lights to work and I could hear a relay or two down by the fuse box just a-clickin. I couldn't get it disconnected fast enough. When I plugged in my second cluster, it worked like a champ.
Please send me the part number if you decide to get a new cluster of one that has a working oil level built into it. I want to do this mod, but want to buy the correct cluster and I don't want to loose my oil level indicator. Mine is a 2001 also.
porsche986spyder is offline   Reply With Quote
