Old 11-06-2004, 01:26 PM   #9
mrmickeymouse
You are running lean with all the backfiring, or your timing is off - nope.
Can you take it back and let them figure it out on there nickle.
~if not~
Check for an air leak with Carb cleaner, spray around after doing a visual check with the engine running. Be careful it's flammable.
If you hit a an air leak the engine will rev a little higher. Manipulation of the the hoses can worsen the problem.
Scott
mrmickeymouse is offline   Reply With Quote
