Okay, now I'm jealous. I want one with the white faces. What year is your Boxster?
By the way, be carefull when changing the faces of the gauges because it usually requires the needles/pointers to be pulled off first before you can put the different color gauge faces back on and can ALSO result in the reading being off. I had some Indiglow guages I put on my last car and it was hard as hell to get the needle to fall in the exact same place as before. Almost imposible unless the Porsche uses a different method. I found out the best way to get the needles to read correctly was to connect everything first and have the gas tank at half full so the needle is exactly in the midle. All the other needles usaully can rest on the small stoppers when the car is turned off.
