Old 05-29-2007, 06:03 PM   #1
mellowyellow2000
Talking FabSpeed Exhaust
I had a FabSpeed cat back exhaust system installed last Thursday. Today was the first time I had a chance to take the car out and play with it.....too many other things scheduled over the 3 day holiday. Here are some observations:
1. Yes it was expensive, but build quality is first class. Plus FabSpeed's system was the only one I found that used larger pipes over the stock system. It is also a true cat back system running from the primary cats to the muffler outlet tips
2. The car sounds great...like a proper sports car.
3. There is no droning with the top down. The car is only driven in good weather.
4. Seat of the pants says the car is faster...might just be that the exhaust note makes it sound faster.
If any of you are going to order the FabSpeed system. Ask for the following to be included with it. One, a packing list so you will know you have all of the pieces. Two, installation instructions. Three ask to have the inlet and outlet pipes on the muffler taped over so the packing peanuts do not get inside.
2000 Boxster S
Speed Yellow
K&N Air Filter
B&M Short Shifter
EVO Billet Shift Linkage
Fabspeed Cat Back Exhaust
Iebach Spring Kit
Goodridge Braided Stainless Steel Brake lines
18" BBS Classix Wheels..Fuch's replica
Aluminum Pedal Kit
mellowyellow2000 is offline   Reply With Quote
