Old 05-29-2007, 02:35 PM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by insite
Carlos -
FYI, the fronts don't go bad so often. the more likely culprit is the sway bar drop links. they make the same sound, but are much cheaper to replace ($55 on ebay).
if you do get the front control arms, definitely have it aligned. you can use their adustability to ensure equal caster from side to side. this is a great feature.
I checked the front track arms when i was under the car removing the bumper, its definatly the track arms, they have a tiny tiny amount of play to the point that if i wiggle them hard enough, i can hear alittle "tick tick tick" coming from inside the bearing cartridge.
Che, do you have any sets of Front Track arms available?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
