Old 05-29-2007, 02:20 PM   #30
delubozparts
Vendor
delubozparts's Avatar
Hello 986forum members,
This is Che and I'm back with 1 new product for your Nice Boxsters, at the bottom is the Installation details provided by CJ_Boxster AKA Carlos.
Now In-Stock and ready for Immediate shipping:
Special GB Price is $249.99 Shipped within 48 States USA, for International is $289.99 Shipped. Please PM me for Questions and Order details, Thank you for your time !
Best Regards,
Che
Originally Posted by CJ_Boxster
Ok This is a DIY on how to replace your Rear Upper Control Arms (Track Arms), However I am not replacing the factory equipment with OEM Rear Upper Control Arms (Track Arms), I will be installing a Set of Adjustable Control Arms purchased from forum sponser DelubozParts. Adjustable Rear Upper Control Arms (Track Arms) are a MUCH LESS expensive alternative inlew of buying a set of OEM Rear Upper Control Arms (Track Arms).
If you have chattering or rattling noise coming from your rear suspension, Chances are that its a worn-out Bearing Cartridge on the Rear Upper Control Arms (Track Arms).
Ok Lets Start,
Tools list: Floor-jack, 18mm Ratchet, 21mm Closed-End Wrench, Torque Wrench, 2 Vise Grip Pliers.
1) Get your floor jack and tool set out. Break loose the lug nuts and security lug on the wheels.
2) Remove the lug that is sitting higher than all others and insert/screw the threaded metal rod into that hole.
3) Now Jack the car up and once the rear wheel is off the ground, Remove the wheel and remove the Metal rod guide from the wheel hub
4) Remove the 2 plastic nuts that hold this plastic cover against the wheel well then remove Plastic cover.
5) Now you can see the Rear Upper Control Arm circled in red. That is what we will be removing/replacing.
6) Time to locate the bolt & nut that secure the "Fork-end" of the control arm to the suspension. Just look behind the Wheel hub, on the lower control arm and you will see this nut and bolt on top and below the lower control arm.
delubozparts is offline   Reply With Quote
