Even if a small metal attachment had to be added, I'm pretty sure the cat heat shield could have been rettached.
Someone needs to invent a bolt-on heat shield for the exhaust pipes where they run under the inner CV boots. When the car is not moving, a ton of heat goes straight up into the boot and destroys the rubber.
