Thread: Custom Exhaust
Old 05-25-2007, 05:57 PM   #21
chaudanova
Originally Posted by Where's my car?
wooah Can you find me some more info on that!! i will forever be in your debt thanks
header wrap? here ya go:
http://www.jscspeed.com/index.html?/univ/thermotec.htm
or maybe you could try this "super sonic acoustical mat"
"This high quality mat offers superior sound dampening control to reduce road noise, rattles, engine noise, and any other noises that are bothersome. The high density polyethylene film with an aluminum foil composite is abrasion and tear resistant. The gray film provides structural integrity & strength, allowing the material to bend, move, & return to shape even under tension forces. The product is 70 mil in thickness, contains a high temperature adhesive backing, and is easy to trim & fit. The rubberized compound is applied with the high temperature adhesive to absorb all those out of control noises."
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
