Originally Posted by porsche986spyder
Funny you said that, because it's the same rear end wide body. Only difference is this company went the extra mile and molded the seems into the fenders and the other company with that wierd front end did not. Same kit, different fronts. 2 different companies.
Do you have a picture of the other car with the rear kit, and the weird front end? And also, any links to more info on that other one as well? I'd like to see/compare to this setup... Thanks in advance
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
