Old 12-29-2006, 01:34 PM   #1
rule1's Avatar
new cross drilled / slotted rotors
what do you guys think?
rule1 is offline   Reply With Quote
Old 12-29-2006, 01:48 PM   #2
i think they look awesome... They'd probably look/work better if they werent on backwards.... The slots have to chop into the air in order to PULL air into the slot channel and between the disc and brake pad... They arent made to Flare out the heat, the slots have to PULL in cool air.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 12-29-2006, 02:01 PM   #3
rule1's Avatar
what do you mean backwards? do I have them on the wrong side?
Old 12-29-2006, 02:07 PM   #4
oh sorry, Yes you have the right side on the left and the left on the right.
I performed my own little test on my non-ABS eclipse with a complete set of Brembo slotted/drilled rotors, they definatly worked better with the slots daggering into the air at the tip of the rotors, not fanning out air/heat.
You'll also notice a SLIGHT bit more of grip during normal braking conditions with the rotors installed the correct way.
Carlos J Cazares
Old 12-29-2006, 02:17 PM   #5
rule1's Avatar
Smile
Thanks alot! Im glad I havent driven alot since i put them on. Guess thats what I am doing tomarrow.
Old 12-29-2006, 02:22 PM   #6
trust me, you'll love it even more. When i replaced my rotors, i made sure to use a bit of sandpaper to knock off about 1-2 millmeters of somewhat glazed brake pad surface so the pad can reseat themselves to the new rotor discs.
Carlos J Cazares
Old 12-29-2006, 03:33 PM   #7
boggtown
Posts: n/a
The rears look like they are on right. What brand are those? Ive been only able to find drilled rotors.
Old 12-29-2006, 04:21 PM   #8
rule1's Avatar
could not wait until morning. CJboxster thanks again! You were right they work alot better when their on the right way.
Old 12-29-2006, 04:27 PM   #9
rule1's Avatar
They are zimmermen got them from Design Rotor Technology #978-454-0692 bought them on ebay $325 plus shipping around $350 total
Old 12-29-2006, 04:51 PM   #10
oh god they are so pretty looking with the rims off!!!!
Carlos J Cazares
Old 12-29-2006, 04:58 PM   #11
rule1's Avatar
I hate these rims, im waiting on my 19s 3-4 more weeks.
Old 12-29-2006, 05:21 PM   #12
Your car is really clean.
What rims are you putting on?
http://i84.photobucket.com/albums/k2...izzlysmall.jpg
'97 986
Cheating Death on 19" Wheels
...no catastrophic engine failure ...yet
Grizzly is offline   Reply With Quote
Old 12-29-2006, 05:38 PM   #13
rule1's Avatar
Thank you I only put about 2000 miles a year on it its my baby and my wife thinks I have a problem. The wheels are at nrauto.com they have so many people wanting them that they had to enlarge their order I have been waiting for a couple of months they promised me I would have them no later than early Feb. I already have my tires. Oh, their called double spoke 19s in black.
Old 12-29-2006, 06:23 PM   #14
Cool. They look a lot like the SSR GT3.
'97 986
Old 12-29-2006, 06:27 PM   #15
rule1's Avatar
Yeah thats them and their alot cheaper than the ssr's. I think they will look good with the white and being lowered.
Old 12-29-2006, 07:58 PM   #16
I read somewhere that zimmerman rotor hats will rust if you don't mask them off and paint them before you install them. Did you treat the hats before you did your install?
Old 12-29-2006, 08:06 PM   #17
rule1's Avatar
they are zinc plated to prevent rust.
Old 12-29-2006, 09:59 PM   #18
boggtown
Posts: n/a
The hats? they are zinc plated?
Old 12-30-2006, 07:39 AM   #19
rule1's Avatar
Yes. If you get on ebay the seller is brakepros and their ebay store is design rotor technology they have 5 available $325.
HTML code is Off
