Old 08-13-2025, 09:33 PM   #41
Rebuilding the heads
These guys are clearly not seating.
Not surprisingly four of them are bent.
Luckily the valve guides are not damaged.
So fresh valves instead of the bent ones should fix it.
Using some grinding compound to improve seating of the new valves.
Lapping.
I had to go back to these ones 2 or three times.
But finally they were sealing.
Inspection for potential deterioration/warpage. Measured with the feeler gauge and a straight edge the difference everywhere was lower than 0.03mm. In the shop manual this is exactly the highest tolerated value for a freshly resurfaced head. The tolerance for a used head that you still can put back on is 0.05mm. Great news, no resurfacing needed.
Coming along.
Homeoboxter is online now   Reply With Quote
Old 08-17-2025, 10:25 PM   #42
Timing, variocam, lifters
I took apart, cleaned and reassembled each lifter. I can't stand lifer ticking.
Soaking overnight in engine oil.
Back again.
Variocam teardown.
New pads and chain.
Reassembled.
Setting the timing and camshaft position.
Almost there!
Old 08-18-2025, 01:35 AM   #43
Interesting project and thank you for posting the progress with images
2001 996 C2 Manual
Old 11-07-2025, 11:39 PM   #44
Finishing up.
Great look onto the sky through the engine bay.
Smog test. Passed!
This is after 500 miles. So far so good.
Old 11-08-2025, 05:01 AM   #45
Thumbs up
Congrats!
Did you expect to take this engine rebuilt one year?
Old 11-08-2025, 05:13 AM   #46
LOL!
Mine has taken four so far, through supply issues and a move.
Hope to wrap this month.
-H. L. Mencken
Old 11-08-2025, 08:21 AM   #47
Congrats!
Absolutely. I'm not a mechanic and I have very limited time for wrenching in the garage with two small kids. And this is not my only one project
HTML code is Off
