Old 05-31-2019, 05:24 AM   #1
Who's askin'?
maytag's Avatar
Boxster trailer hitch
This was a fun little project on Monday.
My car lives a dual- identity. It's my track toy, but if I'm to continue rationalizing ownership, it has to pretend to be a street car as well.
So last season I came to the conclusion that I needed spare wheels with sticky tires. Great. But I'm also Scottish, so I was somewhat worried about the heat cycles I'd subject those tires to on the track commute. The obvious solution was a little trailer, like some if y'all have done.
So last year I built a hitch that attached to the bumperette brackets. I used that to and from the track twice. Seemed fine. Last week I was preparing for my first foray to the track this year (today! Yeah! ) and discovered that both bumperette brackets had a small crack along the top of the mount. I doubt they would've made it to the track again.
So I whipped this one together. Fun, simple, allowed me to dump the bumperettes altogether. The most expensive part was the draw bar.
Maiden voyage this morning!
Old 05-31-2019, 05:45 AM   #2
Those bumperette brackets are only held on with two aluminum rivets. I'm glad to hear you went with a different design. Those brackets can get ripped off very easily. How is the new hitch attached?
Woody
Old 05-31-2019, 08:41 AM   #3
Who's askin'?
maytag's Avatar
I welded 18" of 3/16th steel angle, top and bottom, then bolted it to the back of the aluminum bumper.
Yeah... it ain't going nowhere. Hahaha
As you can see, I relocated the threaded insert for the tow hook, as well.
Old 05-31-2019, 10:13 AM   #4
steved0x's Avatar
My tow hitch is on the bumperettes but I took the whole bar and got the bumperette attachments welded to the bar. Although before that the rivets did hold OK for me, but I felt better after I got it welded. I like your approach, looks really good!
Old 05-31-2019, 01:40 PM   #5
There Is No Substitute.
rick3000's Avatar
Great looking hitch, very clean install, I like that the license plate is hinged instead of offset. Does that hitch have a button that retracts the pins? If so, nice touch, seems like the only way to do it on a 986 without bumperettes!
I have thought about making a hitch to tow my small sailboat. My idea was to mount it using a bolt threaded into the tow hook opening to support the weight and then stabilize the mount using the bumperette brackets.
Old 06-02-2019, 09:49 AM   #6
jmitro's Avatar
very creative, I like it.
any concerns about legality of having your license plate flipped up like that?
07 Porsche Cayman S speed yellow
87 Porsche 924S Carrera GT project/ 951 engine transplant
2015 BMW X5
jmitro is offline   Reply With Quote
Old 06-02-2019, 10:43 AM   #7
WillH's Avatar
Can’t see why. Cars used to have it flip down for access to fuel filler cap.
Old 06-02-2019, 01:16 PM   #8
Who's askin'?
maytag's Avatar
I think that's the premise behind "porschehitch", as well.
https://porschehitch.com/product
Old 06-02-2019, 01:40 PM   #9
rick3000's Avatar
I hadn't seen that before, thanks!
Old 06-03-2019, 04:13 AM   #10
That is exactly how I built mine.
Old 06-03-2019, 02:00 PM   #11
mine uses both the bumperettes and the tow hook to spread the load a bit. no cracks as of yet.
HTML code is Off
