Old 02-10-2016, 07:57 PM   #21
With ramps like in the picture above? Pretty easy. I have done mine that way a couple of times. I like to have the car as level as possible because it helps me feel like I am getting more of the old oil out My driveway slopes down just a little bit so I back the car down the slope and up onto the ramps which levels the car, and there is plenty of room to change the oil.
If you are asking if you can change the oil without ramps or lifting the car - maybe a more athletic person could but I can't...
I was definitely talking about without the ramps.
asteroid hyalosis is offline   Reply With Quote
Old 02-10-2016, 09:29 PM   #22
Without ramps or lifting the car, changing the oil is nearly impossible. My drain pan barely fits under the car without lifting it and I think it's about the same height as you mentioned.
2000 Boxster S 6 speed Guards Red
AaronPDX is offline   Reply With Quote
Old 02-11-2016, 04:15 AM   #23
It's hard enough to get under it when it's on ramps. Buy the low profile rhino ramps that stack on top of each other, they are easier to store that way.
Old 02-14-2016, 01:42 PM   #24
Me and my baby on V-day.
HTML code is Off
