Old 09-18-2012, 10:21 AM   #21
Hows the lighting? Just curious... Better than stock?
Mrmaddbrad is offline   Reply With Quote
Old 09-18-2012, 05:10 PM   #22
Can someone post a picture with them on? I'm curious to see how the smaller led's that surround the projector look...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 09-18-2012, 05:48 PM   #23
http://986forum.com/forums/diy-project-guides/34492-remove-amber-film-headlights-8.html#post306549
Old 09-18-2012, 09:04 PM   #24
Very cool, thank you!
Old 10-21-2012, 12:08 PM   #25
i got mine yesterday. however, i am having a hard time "locking" into place. did anyone have that issue? also, has anyone changed out the main bulb to be "whiter"? would a LED bulb in there be helpful?
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 10-22-2012, 08:10 PM   #26
2001 Arctic Silver 2.7
tony_fury's Avatar
Yes, the lever to secure the light in place is very tight.. I found taking a dremel to the bottom latch indentation of the new light resolved the problem. The tolerance is too tight..
Prior to doing that it would snap hard and smash the projector into the top lens..
See link where others encountered the same.. my post is #141 http://986forum.com/forums/diy-project-guides/34492-remove-amber-film-headlights.html
Hope this helps
T
RMS, IMS, 87.5K
Old 10-23-2012, 10:48 AM   #27
Hope this helps
T
thanks. tony. so, you deeped the grove on the bottom of the new lights, correct? i assume you don't have any pics of this...do you?
-Tuan
tuanle16@juno.com
Old 10-23-2012, 10:50 AM   #28
currently, mine does not "snap" in at all. i can toggle it loose and pull it out. scary. afraid if i brake hard enough, the darn things will just pop off.
-Tuan
tuanle16@juno.com
HTML code is Off
