Old 07-01-2007, 07:30 PM   #1
ddb
www.klisstle.com
ddb's Avatar
Pedal Medal
I've had a set of inexpensive pedals for a couple of months and didn't have much desire to install them. Well, finally this weekend I gave it a go. I also sanded and painted the fuse cover panel. It looked like the original owner wore golf spikes and scraped the panel when entering and exiting the car.
Here's the before:
Here's the after:
ddb
Old 07-03-2007, 04:49 AM   #2
Man those look great, nice job! Was the drilling for install hard? Your Boxster keeps looking awesome!
http://i122.photobucket.com/albums/o...986/986sig.jpg
2002 Boxster S
SC986 is offline   Reply With Quote
Old 07-03-2007, 07:21 AM   #3
Inexpensive to you is expensive to me , those are nice pedals!
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 07-03-2007, 02:16 PM   #4
ddb
www.klisstle.com
ddb's Avatar
Thanks guys.
I had read about how difficult it would be to drill through the brake pedal, so I was prepared. My cordless drill isn't that powerful, so I didn't even try to use it. I just broke out my seldom used old electric drill. On top of that, I bought a new set of drill bits. I then took advice I read here or on another site and started with a very small pilot hole, and enlarged the hole with different drill bits until reaching the desired diameter. Lastly, I removed the plastic owner's manual holder under the steering wheel in order to get a better angle with my drill. After taking these steps, it was rather easy to drill the holes. I made marks on my rubber brake and clutch covers and drilled through rubber before going through the substrate. I believe the rubber acted as a guide and prevented the drill bit from sliding around on the metal or plastic.
I hope these tips will be helpful to the next guy.
ddb
Edit - I forgot to say that I didn't use the rubber brake and clutch covers in the final install. I used them as guides and removed them before attaching the metal covers.
Old 07-03-2007, 03:28 PM   #5
Do you mind me asking where you got them and how much they cost?
porscheman is offline   Reply With Quote
Old 07-03-2007, 04:47 PM   #6
ddb
www.klisstle.com
ddb's Avatar
No problem. I bought them on eBay for $69.99. Shipping was rather high at $25.00. The seller's name is orangehuang531.
ddb
Old 07-07-2007, 04:28 PM   #7
gas pedal question
i poped my gas pedal off and now I can't get the ball back in the cup on the back of the gas pedal, do you know how to get it reconnected/
gpminow is offline   Reply With Quote
Old 07-07-2007, 05:41 PM   #8
ddb
www.klisstle.com
ddb's Avatar
Sorry gpminow, no experience reconnecting the gas pedal. I'm sure someone with knowledge will chime in.
Good luck, and post some pics when you're done.
Old 07-07-2007, 08:46 PM   #9
Send a message via AIM to [z0ne] Send a message via MSN to [z0ne]
Very nice, ddb. The new pedals are a much-needed improvement over the stock ones. If you don't mind me asking, how much did you pay for the set? I assume the set of three came with the dead pedal, too?
[z0ne] is offline   Reply With Quote
Old 07-07-2007, 10:16 PM   #10
Very nice!
Old 07-07-2007, 10:20 PM   #11
Here ya go:
ddb
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 07-08-2007, 04:49 AM   #12
ddb
www.klisstle.com
ddb's Avatar
Thanks guys. The dead pedal was included.
Here's a set listed from the same seller:
http://cgi.ebay.com/ebaymotors/Porsche-Pedals-Boxster-Carrera-GT2-GT3-C4S-996-986-TT-S_W0QQcmdZViewItemQQcategoryZ33700QQihZ015QQitemZ2 50138819753QQrdZ1QQsspagenameZWDVW
They are more expensive than my set ($99.99 versus $69.99), but are slightly different. I actually like these better than the pedals I bought. Shipping is the same, $25,which seems high to me.
ddb
Old 07-14-2007, 11:40 AM   #13
Originally Posted by chaudanova
Here ya go:
Duhh. Sorry. I don't read; I just look at pics :ah:
Old 07-14-2007, 06:21 PM   #14
Pedals
Looks great! Can I ask, did the aluminium pedals raise the pedal height? I am ~ 5'10" and was wondering if I did this would it feel to high? Thanks
kelsey is offline   Reply With Quote
Old 07-14-2007, 11:15 PM   #15
ddb
www.klisstle.com
ddb's Avatar
Hi kelsey,
Thanks. I drove the car for the first time since installing the pedals 3 days ago. I'm about 6 hours away from home and didn't notice anything odd about the pedal height on the drive. I removed the brake and clutch stock rubber covers which probably offset any net gain in pedal height.
On longer distances I like to drive with my shoes off (socks on). The only thing I noticed is the nice feeling of the raised pieces on my feet when depressing the pedals.
Post pics if you decide to add the pedals.
Thanks,
ddb
Old 07-15-2007, 11:34 AM   #16
What did you like better on the other set. The only thing I noticed was Porsche written a it bigger. Is there a slight different in finish?
2002 Boxster S
Old 07-15-2007, 03:26 PM   #17
ddb
www.klisstle.com
ddb's Avatar
Hi SC986,
Two things: The raised pieces appear to be cylindrical and made out of rubber on the set in the link. Mine are plastic and domed shaped. I think the cylindrical set looks better.
Also, mine are attached with just 2 screws per pedal, versus 3 on the set in the link.
Did you get your top? How do you like it? Pics!
ddb
Old 07-15-2007, 04:57 PM   #18
Yeah got the top painted and on last Thursday. I like it, it really gives the car a different look. I need to do some adjustments, have alot of windnoise on the drivers side.
I tried for 45 minutes today and could not get the plug for the defroster clipped in..Grrrr.
Yeah, I haven't taken a pic yet. You know the area, no great scenery around. I need to though!
2002 Boxster S
Old 07-15-2007, 05:26 PM   #19
ddb
Hmm, I like it - might have to look into a set for me.
Happy Motoring!... Tim’05
http://i153.photobucket.com/albums/s..._kill/Siga.jpg
Dr. Kill is offline   Reply With Quote
Old 07-15-2007, 11:19 PM   #20
ddb
www.klisstle.com
ddb's Avatar
SC986:
It's a bear to get your hand contorted enough to plug in the defroster cable. Keep trying and you will get it in. Looking forward to seeing the hardtop.
Dr. Kill:
For the money I think those pedals offer a great bang for the buck! Post some pics if you decide to install a set.
ddb
HTML code is Off
