Old 06-06-2020, 02:30 PM   #1
Coolant Bleeder Stuck Open?
I've been tracking a coolant smell in the trunk of my 99 Base Boxster.
There was some residue around the bleeder and cap, so I cleaned them off, replaced the o-rings and cap. No more residue, but it's still got a smell in that area.
Reservoir was replaced 2 years ago by the previous owner.
Today, I realized the bleeder was open by itself. The wire is loose, and the middle "stick" is "up" There is a running water/visible turbulence in the tank when it's like this.
If I push the "stick" down, the turbulence immediately stops, but as soon as I let go, the stick moves up, and the "running water" starts again.
Driving the needle is between the 8 and the 0, sometimes moving closer to the far edge of the zero.
Does this sound like a typical bleeder failure?
Thanks.
-Eric
99 Base 986
Eric-986 is offline   Reply With Quote
Old 06-06-2020, 07:38 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
If the replacement tank wasn't oem, the bleeder valve could well be sub-par. I had a bleeder valve split wide open at a track event causing a dump of coolant just in front of my right rear wheel during a hairpin turn! You can imagine what happened! I'm all for aftermarket but coolant tanks and their bleeder valves need to be top notch!
Old 06-08-2020, 01:15 AM   #3
Too much pressure , can cause it to stay open
dunks is offline   Reply With Quote
