Old 10-14-2006, 06:14 PM   #1
Spark Plug Question
My box is due for a Spark plug and oil change. I saw online some new bosch spark plugs that infuse iridium plus the plat +4 thingamajig. Is there any real difference from using these spark plugs from the oem ones ? What can I really expecto from these, I'm not expecting a single (1hp) from them but what difference do they make ?
BoxsterRS is offline   Reply With Quote
Old 10-14-2006, 08:01 PM   #2
Most of the rare metal sparkplugs out there are mostly a marketing gimmick. They will also last longer in some applications.
But, this is a false economy because you really don't want the plugs in for more than a couple years anyway. You really need to pull them to inspect them at least every 2 years and especially with the Boxster's Coilpak-on-plug, it's just as easy to swap them out when you do the inspection. Also, leaving them in for more than 2 years in an Aluminum Head can sometimes cause them to sieze.
A big factor in using OEM plugs is that the manufacturer (Porsche) set-up the taps in the Head so that the plugs will be properly indexed (electrode open to the desired Flamefront, as opposed to away from it) when properly torqued in place. If the plugs are not properly indexed (aftermarket plugs will be a crapshoot and usually off unless you go the Helicoil route and frankly it's not worth it), MPG may suffer mildly and the idle can be rough or hesitant.
A final issue with Aftermarket, or non-OEM plugs may be their Heat Range. There is no Industry Standard on this and each manufacturer's plugs have differing heat dispersion characteristics. While it's usually true that going from one heat rating to another increases or decreases the plugs heat dissapation by 85° - 100°F, it still doesn't guarantee that the plug from manufacturer X has the same heat characteristics than those from manufacturer Y, even though they share the same Heat Rating #. Unknowingly using plugs with an improper heat range can have effects which aren't noticed in the near term, but are potentially damaging nonetheless in the longterm.
There have been some reports of the Platinum tips breaking off on some of the earlier models causing damage to the pistons, heads and valves. If yours are spec'd as 4 prong, then go ahead. If not, best advice is to stick with OEM. Hope this helps...
Happy Motoring!... Jim'99
Old 10-15-2006, 11:20 AM   #3
Go OEM for spark plugs!
For a Porsche or any other German car I would ONLY do OEM. Most advertisement claims are false and are marketing ploy for you to purchase their products. Do yourself a favor and stick to OEM Engine parts only. Its the safest way to go bro! Good luck!
chgolatin2 is offline   Reply With Quote
Old 10-16-2006, 09:44 PM   #4
Porsche "Purist"
Paul's Avatar
Check this source:
https://www.************************************************************
Old 10-17-2006, 07:52 AM   #5
Perfectlap's Avatar
unrelated but interesting.
I saw the spark plug from an F1 motor and its 1/3 the size of what you might find in the Boxster. The teams were all complaining that for its size it was the heaviest component in the engine. So Champion redesigned the "most sophisticated spark plug" in the world into one the size or a double a battery..... cool.
