Old 01-05-2020, 01:49 PM   #1
Kboggs's Avatar
May have found a solution for the drone on the cheap ebay exhausts!
With no major modification. Someone on a 986 facebook page installed this baffle that is $10 on amazon! I have one i took off my cat due to the drone, wish I hadn’t now, but if anyone wants to pick up in the charlotte nc area.
Kboggs is offline   Reply With Quote
Old 01-06-2020, 04:40 PM   #2
Is the low drone better or worse for your ears. Those rumbles you hear on some bikes are the worst. An hearing aids can be more expensive than any good muffler system.
Old 01-06-2020, 10:20 PM   #3
You buy a less restricting exhaust then add more restriction to it... not very logical to me. I know this is about a cheap solution for more sound, but in that case I'd rather gut out and reduce restriction inside the stock exhaust, cutting out inner pipes, add bigger bypass holes, etc.
Old 01-07-2020, 04:24 AM   #4
98 Arctic silver 986
tommy583's Avatar
I have tried the baffle set up in a cheap Ebay exhaust. I tried different size ones, different places in the exhaust, only one side and both sides. In the end I was never really happy. I ended up just modding the stock muffler. So much better. It sounds like a proper sports car now and no drone.
Old 01-07-2020, 05:39 PM   #5
So Tommy what exactly did you do to the stock muffler ?.....I have a 99 base with the stock muffler and would like to hear what you did.
99 Roadster base / 5 SP Tiptronic
18" Turbo Twist wheels / Arctic silver W/Black leather Int
Rear wing W/Brake light / 47,000 miles
Side skirts / Bought from original owner
99Roadster is offline   Reply With Quote
Old 01-08-2020, 04:12 AM   #6
Speaking for myself I wanted an aftermarket muffler for weight savings and sound . The OEM muffler is a tank . I have used a GHL with inserts in the tips and it was close to what I wanted but not quite . I have used a Mille Miglia which is a single can muffler similar to stock .
The MM I have not played around with inserts yet , I think it has great potential . I pulled the MM and am currently running a stock S muffler with bypass pipes . My engine is very unique and has a VERY unique exhaust note . I was very surprised how loud the S muffler is with the bypass pipes .
Going on memory the GHL is 20 lbs. lighter than stock , the MM is about 15 lbs. lighter . That is a lot of weight removed hanging under the bumper . In my opinion taking a high flow muffler and tuning it for the sound you want is ok , I highly doubt tuning it will ever make it as restrictive as the stock muffler .
Old 01-08-2020, 04:52 AM   #7
tommy583's Avatar
This is what you need http://986forum.com/forums/diy-project-guides/70112-internal-exhaust-mod.html
Old 01-09-2020, 02:48 AM   #8
I second that.
A few pounds is well worth proper sound with no drone.
Old 01-09-2020, 06:52 AM   #9
As a casual observer of these drone topic threads, it seems to me that the cheap eBay mufflers drone because one thing they all have in common is there is no cross-over pipe between the two mufflers. So there is a completely separate exhaust system for each cylinder bank and at a certain rpm the two separate exhaust streams create the drone. If you look at the Fabspeed maxflo muffler it has a cross-over pipe between the two mufflers and their latest edition also has a cross-over pipe in the exhaust tips too. The Fabspeed unit is a lot more money than the eBay ones, but perhaps adding a cross-over pipe between the two mufflers on an eBay unit would eliminate the drone.
Old 01-09-2020, 07:01 AM   #10
tommy583's Avatar
From what I've heard the Fabspeed exhausts still have some drone. The maxflow has less drone than the race muffler setup. I've also seen threads on here with people welding in a crossover pipe on ebay mufflers, they report that there is still drone. I stand by the internal mod as the most cost effective solution, followed by the external pipe mod.
Old 01-09-2020, 07:14 AM   #11
Good to know, so far I have held off on changing from my stock muffler. I would hate to spend the $1,600 for the Fabspeed unit plus installation labor and get some drone. My car sounds great to me with the stock muffler, Fabspeed Sport headers and Circuit Werks mid-pipes.
Old 01-16-2020, 01:42 PM   #12
What size for the insert?
I have 2 pairs of flowmaster hushpower mufflers that drone nicely between 2.5-3k. I found a shop that can install a cross over pipe for about 200 and make it removable for clutch, etc. It is going to be tight but with the skid off there is room to match the stock size exhaust pipe. Flowmasters are 2 inch, smaller bodied mufflers. Took out second cats... These were supposed to help with drone but its the off setting exhaust pulses from cylinders that the boxer has that creates the drone with two seperate banks.
https://www.holley.com/products/exhaust/mufflers/laminar_flow_mufflers/super_hp-2_series/
For 10$, I might try finding a home on the passenger side pipe instead of engineering a J-Pipe and trying to isolate the hZ that causes the drone.
For us boxster owners, we only have about 8 feet of exhaust so if you have ever dumped an exhaust under a Jeep or Truck, you know how loud it can be ever with 6 cylinders!
aparke4 is offline   Reply With Quote
Old 03-16-2020, 12:44 PM   #13
Confirmed. I put a Fabspeed Maxflo on my 2001 Boxster S, and while it sounds fabulous above 4000 rpm, the drone between 2000 and 3000 is a drag. I'm thinking of doing the internal mod to my OEM muffler and putting the old system back on. Or maybe keep the Fabspeed cats and bypass pipe and graft the old muffler on. Has anybody done this?
PeterBleakney is offline   Reply With Quote
Old 03-16-2020, 04:29 PM   #14
I would imagine it would be easier to just buy a set of cat bypass pipes on ebay (I paid about $150 for mine a few years ago) than to make the fabspeed mid pipes work with the stock muffler and u-pipes. I have a set on my 04 S with the stock headers and muffler. I'd prefer it a bit louder, but the trade off is that there is absolutely no drone. The car sounds more or less stock except at full throttle and/or high rpms where there is a nice rasp and a bit more volume. I've driven a Cayman with the maxflo system and know what you mean about the drone/resonance in that rpm range.
Old 03-16-2020, 04:35 PM   #15
Thanks for this!
Old 03-16-2020, 05:32 PM   #16
Qingdao's Avatar
Got my cheapo ebay muffler, but I'm not running a stock engine. So I hope it doesn't drone.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
Old 04-23-2020, 11:58 AM   #17
Somewhat related experience
Hey folks I'm still relatively new to the Boxster. Had mine for only 18 mos but have read a lot of exhaust threads trying to understand options and potential for drone.
I also had a Fiat X1/9 (don't laugh -- they're fun) that droned horribly after I put a performance header and exhaust on it. I used inserts like the ones shown here and they reduced the drone but never eliminated it. Most of insert companies recommend stuffing them with steel wool or adding more baffles to further calm the drone -- but then you're also reducing the performance of your exhaust. A good company with a lot of experience developing baffles is here: https://www.carchemistry.com/
Several forum members indicate that the stock muffler and larger/heavier aftermarket mufflers don't drone because of their mass.
Seems clear that long-tube headers, removal of cat restrictions, and a lighter muffler will cause drone every time in our Boxsters.
The question is, can you change some of these items (header, and/or midpipe, and/or muffler) to improve performance or reduce weight without adding drone -- or incurring minimal drone.
geekdaddy is offline   Reply With Quote
Old 04-23-2020, 01:16 PM   #18
Hello Geekdaddy, I had several X1/9's as well, and actually got married on one :-)
You can imagine the bride on the passenger seat with the wedding dress and all the trimmings on..
Old 04-23-2020, 04:05 PM   #19
Dave80GTSi's Avatar
I bought my 1978 X1/9 new, and sold it in 2016 (38 years later) because I stumbled across my 2000 S at a price too good to pass by. My garage was not large enough to hold yet another car, and so something (the X) had to go.
Farewell pictures that I took before I sold it: https://s1152.photobucket.com/user/dave80gtsi/library/1978%20X1-9?sort=9&page=1
Perhaps we should start a new "X1/9 Appreciation" thread!
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
Old 04-23-2020, 05:09 PM   #20
Dave, thank you for the pictures, that was a beautiful X1/9 !! I am sure that you sold it very well.
The only thing I would have done to it, was first to remove the ugly ladder bumpers and replace them with the '74 bumpers and second to install the Uno Turbo engine that has been sitting on my garage for more than a decade..
Thank you for sharing this pictures :-)
PS: My first X1/9 was a 1980, then a 1986 (the one I got married in), another 1986 (bought NS around 1998-99) then another 1984-85 (..?) and a '74 that I was planning to restore but lost the storage (and the car..)
