Old 06-28-2019, 05:47 PM   #21
JayG's Avatar
It makes sense that a bigger contact patch would give you better braking.
Topless has a lot of track experience and has a good handle on what he is talking about. Between him and his brother, they probubly have tried just about every posible setup on a Boxster
Old 06-28-2019, 05:54 PM   #22
steved0x's Avatar
Originally Posted by Boxstard View Post
Who has gone 225 up front from 205 stock, and if you have, any appreciable benefits or downsides?
Also with added traction with 225, did you also have to upsize front sway bar to counter oversteering?
Me, all benefits, did not have to upsize the front bar, the 205/255 stock stagger is so heavily biased towards understeer that moving to 225 in the front just helps dial some of that out, but still leaves a slight understeer bias.
Old 06-29-2019, 02:35 PM   #23
Sounds good. I got a beefier non-S M030 sway bar in back already, still not oversteering, so hoping 225 fronts dial it just right without needing a thicker front bar.
