Old 05-08-2018, 02:56 PM   #1
warped new rotor?
Installing new ATE vented front rotors on my 02 Boxster S and discovered a severe wobble in the left rotor. Reinstalled it several times, still there. I removed it and checked the runout at the hub and it was negligible so I'm sending the rotor back. It must be warped. I'm a bit surprised. These are not bargain-basement rotors. Then again, they're not super-expensive OEM either. I have a replacement on the way. Is this rare? Or not so rare?
jandr95 is offline   Reply With Quote
Old 05-08-2018, 04:30 PM   #2
Since I replace my pads and rotors at least twice a year, I have gone through a lot of rotors over the past 6 years. In that time I've had one rotor that was actually warped.
However, I recently had another rotor that needed the center hole to be opened up a few mm so it would fully seat on the hub. It would get 95% of the way onto the hub (visually it looked fully seated) and then bind on the hub alignment tabs. The rotor acted like a warped rotor on the car but had no runout at the hat or at the outer edge of the rotor on the bench. WTF? Then I checked the hub and it was fine. WTF #2. I installed/removed it four times before I finally found the seating issue which I was able to fix it with a hand file.
So I'd say that while manufacturing defects are somewhat rare, they can and do happen.
Old 05-08-2018, 04:36 PM   #3
BYprodriver's Avatar
May simply be from improper storage, the braking surface should be at the bottom so it rests on the shelf flat surface.
