Old 12-20-2017, 06:45 AM   #1
AZ986S's Avatar
New wheels
I loaned the Boxster to my GF last week and she enjoyed it immensely until... well let's just say I need a new rear suspension, wheels and tires Thankfully she is fine and there doesn't appear to be any body damage or anything to the front wheels (so far).
So I'm having the car done at my usual trusted Indie (McIlvain Motors) here in Tempe, AZ. Will need the following:
On both rears:
*Lower control arms
*Trailing arms
*Toe control arms
*New wheels
On right rear:
*New axle
On all 4:
*New tires
I am wondering if the wheel bearings or sub-frame could be affected by those impacts to the rear wheels... The transaxle appears to be OK. I will have Wheel Specialists in Tempe look at all 4 wheels and tell me which ones are bent, but I already know both rears are. Then I have to figure out what I want to do for wheels. Do I just replace the 2 rear with the 18in Turbo Twists that I have? These are for street only as I have a set of dedicated track wheels.
I've always liked the Cayman 987.1 wheels... (courtesy of a fellow forum member)
Or the Carrera lights...
Are these true OEM?
Porsche Cayman 2007 18" OEM Front Wheel Rim
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 12-20-2017, 08:21 AM   #2
Cayman wheels
I had a 2013 Boxster S and bought a set of Cayman wheels for it. Sold the 2013 and bought a '97 Boxster, Cayman wheels won't work on the early cars but would on later ones. contact me is your interested? rogerkatz47@gmail.com
Roger Katz is offline   Reply With Quote
Old 12-20-2017, 11:29 AM   #3
Cayman heels for sale
These were the offs with nearly new German Goodyears, excellent condition. Contact me at rogerkatz47@gmail.com
Old 12-20-2017, 12:06 PM   #4
AZ986S's Avatar
I assume those are 981 Cayman wheels. Not sure they would fit my car. I was thinking along the lines of a 987.1 Cayman.
Old 12-20-2017, 12:51 PM   #5
steved0x's Avatar
That wheel you linked, I couldn't zoom in enough to see if it had the embossed numbers around the valve stem, which is how you tell if a wheel is the Porsche OEM wheel instead of a replica. This works for most Porsche wheels except for some of the hollow turbo twists wheels (I think that some of them don't have the embossed numbers)
You should be able to score a set of those 18" Cayman S wheels for $1000 or less.
Old 12-20-2017, 01:16 PM   #6
seningen's Avatar
Let me guess -- the rear end got squirrelly and she lifted :-(
My wife did the same thing on my old S -- fortunately she missed everything
and stopped 2' from a retaining fence at the bottom of the ravine. How she missed
the curb, 3 poles, and god nows what else -- IDK.
I was even able to mud race it out of there.
Took a good power washing -- but no worse for wear.
Mike
On both rears:
*Lower control arms
*Trailing arms
*Toe control arms
*New wheels
On right rear:
*New axle
On all 4:
*New tires
Are these true OEM?
mike@lonestarrpm.com
Old 12-20-2017, 06:17 PM   #7
AZ986S's Avatar
New or used? Where?
