11-19-2006, 09:48 PM
#21
Non Functional window Reg.
What type of noise do you hear and does the glass move at all?
Does the W/R make a grinding noise or does it just hum?
Try to push and raise the glass down by hand. It should not move more than 8 or so millimeters. If it moves alot you've got a broken cable. If it does not move you may have a jammed cable or a dead motor.
Windsor, Ontario Canada -- Silver 98 Boxster with black interior 90k kms -- Weekend toy, summers only
11-20-2006, 03:25 PM
#22
sound
well here is the thing there was a sound at one time but now when i hit the window switch i get no noise. I can not push the window down at all. I checked to see if it was the switch by swapping the plug for the passenger window but the window still wouldn't go down. i ordered a window regulator and motor. What are the chance that it's the motor? It's a 1997 porsche boxster with 93k.. when i called the place where i got the motor and regualtor he said very rare for the motor to go out. So please any advice to the updated info would be greatly valued
I also can't mannually push down the window it seems like a rock.
11-20-2006, 04:30 PM
#23
Glass Movement
Can you lift the glass at all?
11-20-2006, 04:36 PM
#24
i had similar problem, it ended up being the regulator only. cost me $200 even with installation. ther was no way i was gonn do that myself in 30 degree chicago weather at that time
my cardomain/pictures page
11-20-2006, 06:41 PM
#25
no movement with the window. I can not move it all with the switch or by hand
11-20-2006, 08:44 PM
#26
just so i explain it right the window right now is closed. The top of the window will not tuck under the rubber gasket on the hard top. When i press the switch nothing happens and if i tried to push window down manually nothing happened. It won't move at all. My question is if i am going to change the regulator or motor how do i get the window down to access the bolts i need to get to ? I am figuring it is my regulator that is burnt out. At this point I will wait for more info. I am trying to be as clear as possible . Thank you for your help
11-21-2006, 03:47 PM
#27
Power Window Relay
Can someone tell where is the relay for the power windows. Also is there more then one relay for both windows. What I mean is there seperate relay for left/side windows. Pictures would be great
11-21-2006, 05:53 PM
#28
There is no relay(s) for the power windows.
11-22-2006, 06:55 AM
#29
Window motor/Regulator
So the only way to see what is dead would be to take it apart. Does anyone know if there is any other way to test if the motor is still good. Thank you for the answer about the window relay. Also how do i get the window down to access the bolts on the clamps holding the glass. Is there some kind of trick. I have read the window project but do not see anything about if your window is stuck in the up position.
11-30-2006, 08:31 PM
#30
Update
Well i went ahead and bought the regulator / motor installed in and nothing works still. Seems like no power going to the window. I am so confused since i check the fuse ad people are saying there is no relay for the windows. My passenger window is working fine. Anyone have an idea what it could be? I checked the plug in the box under the seat it seems to b plugged in . There is only one plug i can feel . Please help me out alittle.
01-08-2007, 11:49 AM
#31
I have a similar problem. However, my door window operated normally when opening the door. It just doesn't lower the window quite enough to clear the top frame when I go to close it. It lowers a bit, but not enough to clear. It bangs into the top frame every time I close the door with the window up. Is this the same issue as everyone else?
01-08-2007, 11:59 AM
#32
oversteerdawg: You are describing classic regulator wear. It either stops dropping that 1/4 inch, drops at the front or the back but not both, won't raise after it drops, or the window just won't go all the way up or all the way down.
01-08-2007, 12:01 PM
#33
If you haven't gotten this problem solved yet, it could be the window switch in the center console. They do wear out eventually.
01-08-2007, 12:45 PM
#34
Window Dip
I had the same problem (2002-base) but have an extended warranty through Momentum Porsche here in Houston- they replaced the door switch and also the regulator. Solved the problem.
Big Trouts
01-08-2007, 01:15 PM
#35
Big Trouts: Glad to hear of another boxster owner in Houston on this forum. keep an eye out for a new thread I'm about to start about a boxster meet in two weeks!
01-08-2007, 01:48 PM
#36
Boxster Meet
Keep me posted too RN, I'm up for a drive. -Will
01-03-2008, 01:09 PM
#37
Did you fix the problem oversteerdawg?
I'm just wondering,
is that the regulator problem?
anyone please help me solve this problem.
thanks.
02-13-2017, 10:10 AM
#38
I'm reviving this ancient thread because there's so much information here to read and I'm kind of stuck with my 986 window problem. I replaced my battery last weekend, and afterwards the driver's window is acting a tad squirrely. The window goes up and down fine, but when I shut the door from the outside the window doesn't drop quite far enough -- making contact with the top frame. As a result, the door doesn't close properly.
The window drops as it should (the drop-down feature as you open/close the door) but as I shut the door the window pops back to its home position before the door is closed. It's as if the timing is off or something. Is the a symptom of the faulty regulator? It's just odd that it all started happening when the battery was replaced. (Also, for some reason by windshield washer pump stopped working).
1999 Boxster; Arctic Silver with Metropol Blue top. No mods... yet.
02-14-2017, 05:20 AM
#39
Sounds like the door lock or inner handle micro switch. This happened to me and it was the door lock unit. In contrast, when my regulator went out (removed I found lots of slack from wear), it wouldn't drop enough opening or closing.
All this before 80K miles
2002 Lapis Blue Boxster S
02-14-2017, 12:04 PM
#40
Did you go through the window reset procedure? Lower window, then raise and hold for several seconds after it has reached the top position. This lets the window controller know where the top window position is.
1941 Dodge Luxury Liner Coupe
